I need some help, maybe somebody can help me.
I` heaving central heating and used manual Giacomini R470 thermohead to control room temperature.
Now I bought Fibaro Heat Controller and additional temperature sensor. I also bought R453H Adaptor (Giacomini valve connection to M30x1,5 mm)
Main reason, room temperature is very high and I wanted to control it using HCL.
But the problem is that if I use RED temperature range (24°C or higher) it seams that it closes valve.
If Magenta - Valve opens and it is very hot.
Now it set to 24°C  and HOLD, but radiator are cold. Temperature sensor is showing 23.5 °C
Maybe I missing some configuration to control more flexible?
If I set Green temperature range, Motor is closing valve. If I change to RED, nothing happens. But if Magenta - motor is working and it need some time to finish.
Also from Magenta to Red seams that motor working too much.
Thanks in advance.
Edited by FSC_DS
