Hello everybody, I would like to buy an outdoor camera to connect to Fibaro, I can give a tip which camera without problems with Fibaro integrators let.
I'm grateful for every tip
5 answers to this question
Any cam with mjpeg stream.
I use Hikvision DS-2CD2185FWD-I (in combi with a Hikvision NVR) and the camera's just work fine.
FOSCAM FI9828P V2
Edited by colvs
Hi, I also have HIKVision Cams and HIK NVR, do you get the feed from camera or from the NVR? Any example config would be appreciated. Thanks in Advance
Jason
I use the feed from the camera, from the NVR doesn't work with the Home Centre. The NVR has its own network, not reachable from outside the NVR.
The configuration of my Hikvision camera is:
IP Address (including port if needed): = your local IP address
protocol = http
JPG path. If you choose a camera from the list, this field will be filled in automatically. Otherwise, please use URL address specified in device's owner's manual: = ISAPI/Streaming/channels/101/picture
MJPG stream path. If you choose a camera from the list, this field will be filled in automatically. Otherwise, please use URL address specified in device's owner's manual: = ISAPI/Streaming/channels/102/preview
Display camera image at Your House, advanced options: = JPG
