Calf 1
I installed a RS3 to venetian blinds, but for the sake of this post, consider them as simple Blinds with Positionning (I'll post another question on another bug I see).
It is all working fine from the HCL UI, but as soon as I try to use a secondary controller (Remotec ZRC-100) or a switch (ZWave.me), it doesn't work right and, in both cases, with the same wrong behavior. So it makes me think this a RS3 issue.
So, I setup the association between my RS3 and the switch (double buttons, no double clicks, in the right association groups, etc.), I get the following behavior:
I've tried with the Remotec ZRC-100 and the behavior is exactly the same.
Note: I have no switch associated to the S1/S2 ports on the RS3, I'm using it only remotely.
What's wrong? Is this a firmware bug?
