Problem in Wiring Fibaro Switch for unipolar swtich
Ciao to everybody,
I purchased 2 FIbaro switches.
First one to remote control a wall mounted socket. it works PERFECTLY :) using this scheme:
now I am getting crazy to configure the second fibaro switch.
I want to use it to remote control a unipolar switch (please note that in Italy we only have Phase, so layout under my switch is following one (two black cables):
I have no issues at all to integrate also a NEUTRAL, but I literally don't know how to wire everything. Can someone help me with a scheme?
Thanks!!! :)
Edited by *asbesto*
Hi, @asbesto
If you have the Fibaro single switch FGBHS-213 for homekit, the Installation guide ist
Best Regards, Fabir
Edited by Fabir
    Ciao Fabir,
    I used it but no luck, that's why I ask for more help :)
    You also need a (blue) zero leader. Without it your switch will not work.
    I attached the two blacks (one to S1, the other one to L) and then the blue to N, ando nothing works :(
