Fro 1
Hello!
I need help to create a scene in which the switch not connected to the light source will imitate the switch that actually turns on this light source. I have a switch (DummySwitch) next to the bed, which I would like to be able to turn off the light controlled by the switch next to the door. Of course, I also need cross on/off possibility: when one can turn off the other.
I did not find similar scene, so I tried to write it myself, but I can't do it
All in all, everything works except when I'm trying to turn off the light by DummySwitch.
Please, I need Your Help.
I have a Fibaro HC2 for a few days, and this is the first scene in LUA which I try to make - so please: be gentle
%% properties
740 value
736 value
%% events
%% globals
fibaro:debug("SCENE START --------------------------")
fibaro:debug("sceneInstance: "..fibaro:countScenes())
if
fibaro:countScenes() > 1
then
fibaro:debug("SCENE ABORT --------------------------")
fibaro:abort()
local switchID = 736
local dummyID = 740
local switchTurnedOn = (tonumber(fibaro:getValue(switchID, "value")) > 0);
local dummyTurnedOn = (tonumber(fibaro:getValue(dummyID, "value")) > 0);
local switchTurnedOff = (tonumber(fibaro:getValue(switchID, "value")) == 0);
local dummyTurnedOff = (tonumber(fibaro:getValue(dummyID, "value")) == 0);
local isTvLightOn = (tostring(fibaro:getGlobal("isTvLightOn")) == "true");
local isTvLightOff = (tostring(fibaro:getGlobal("isTvLightOn")) == "false");
if
switchTurnedOn
then
fibaro:debug("isTvLightOn: "..tostring(isTvLightOn))
fibaro:debug("Real Switch ON - turnOn dummy one")
fibaro:call(dummyID, "turnOn");
fibaro:debug("Dummy Switch ON")
fibaro:setGlobal("isTvLightOn", "true");
fibaro:debug("-changes into:")
fibaro:debug(fibaro:getGlobal("isTvLightOn"))
if
switchTurnedOff and isTvLightOn
then
fibaro:debug("Real Switch OFF - turnOff dummy one")
fibaro:call(dummyID, "turnOff");
fibaro:debug("Dummy Switch OFF")
fibaro:setGlobal("isTvLightOn", "false");
if
dummyTurnedOn
then
fibaro:sleep(1000)
if isTvLightOff
then
fibaro:debug("Dummy Switch ON - turnOn real one")
fibaro:call(switchID, "turnOn");
fibaro:debug("Real Switch ON")
elseif
isTvLightOn
then
fibaro:abort()
if
Edited by FrodummyTurnedOff
then
fibaro:sleep(1000)
if isTvLightOn
then
fibaro:debug("Dummy Switch OFF - turnOff real one")
fibaro:call(switchID, "turnOff");
fibaro:debug("Real Switch OFF")
elseif
isTvLightOff
then
fibaro:abort()
typo
