Changing label of Virtual device with HTTP command
I have a HC2, and I am looking for the HTTP command for changing the value of a Virtual Device.
I found all kind of HTTP commands to turn devices on and off, or to start a scene, but i can't find the command to put a value in a label of a virtual device.
I think it has to be something like:
http://<ip-address>/api/callAction?deviceID=<virtualdeviceid>&name=
Can anyone help me?
7 answers to this question
@RonOud
Check out the following posts:
    @Barlow
    Thanks for the response.
    I checked both posts, but I only see solutions for changing the label of a VD with Lua code from within the HC2.
    I'm looking for a http command which I can use to change a label of a VD from outside the HC2, the same way as I can turn on a device with a http command from outside HC2 (http://<ip-address>/api/callAction?deviceID=<virtualdeviceid>&name=turnOn)
    I do not know a direct api call for your Problem. But you could create a scene with the LUA code for changing the label in it and execute it with a http request as a workaround.
    The problem will be... you cannot push values to use as Label.
    Edited by StefanS
    Guest skarotech
    Yes, you can do it via HTTP post command,
    create a string like so
    {"args":["ui.XXXX.value","123456"]}
    where XXXX is the name of the label, and 123456 is the text you want on the label, then do a post of the string to
    http://#fibaro_ip#/api/devices/#fibaro_id#/action/setProperty
    You can also do the same for sliders
    {"args":["X","#device_value#"]}
    where X is the position number of the slider in the VD, and the post to
    http://#fibaro_ip#/api/devices/#fibaro_id#/action/setSlider
    Edited by skarotech
    @skarotech
    I don't know understand the part with creating a string how it is constructed.
    I tried it with a piece of PHP code like this:
          $url = 'http://<ipadress>/api/devices/<deviceid>/action/setProperty';
          $myvars = ???????
          $ch = curl_init( $url );
          curl_setopt( $ch, CURLOPT_POST, 1);
          curl_setopt( $ch, CURLOPT_POSTFIELDS, $myvars);
    But how exactly must the piece of string look like?
    Guest skarotech
    @RonOud
    {"args":["ui.XXXX.value","123456"]} is a JSON object, you will need to create this in PHP as JSON, then send it as a string
    see
    @skarotech
    I'm terrible with JSON. I have tried several things to get the string layout via a JSON object, but with no succes.
    Somehow I have to put 2 values
          $data = array(
              (object)array(
                  'args' => 'ui.zon.value' , '123456',
          $myvars = json_encode($data);
          echo "$myvars";
    The output of the variabele is: [{"args":"ui.zon.value","0":"123456"}]
    When I try this:
          $data = array(
              (object)array(
                  'args' => '123456',
          echo "$myvars";
    The output of the variabele is offcourse:  [{"args":"123456"}]
    The second overwrite the first one.
    Can you (or anyone else) help me to get this correct.
    Edited by RonOud
