Advanced Battery Check VD
; I have installed your Advanced Battery Check VD and it work however I am getting 5 battery error checks of devices of which the battery should be below 35% (red X% mark) so I have changed the batteries of 2 of those device but no change in the battery check status. Strange it is that the HC2 controller shows in the device section that the batteries are full.
Any idea what is causing the problem of not showing the correct battery status/value while the rest (60%) of the other battery devices are giving correct values!?
The image shown is the battery with the cross in the middle of the image and which greyed out!
