Sjakie 157
I converted a few "block"schemes into LUA through the system.
Now I have a few scenes without running instances so they does not start. hat is wrong? Any guidance in the right direction will be highly appriciated.
In the debug window nil
%% autostart
%% properties
%% weather
126 value
%% events
%% globals
timeNow = os.date("%H:%M")
local EveningStart = os.date("%H:%M", os.time()-5*60)
local EveningTime = "17:00"
local StopHour = "23:30"
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
--if (sourceTrigger["type"] == "autostart") then
--tempFunc()--
local GordijnVoorzijde = 48
local GordijnVOpritijde = 50
local GordijnFietsenzijde = 52
local KeukenkastjePlint = 20
local SpotKastLinks = 10
local GordijnAchter = 44
local GordijnZkantachter = 46
local SpotBeeld = 32
local LichtsterkteBuiten = 126
if timeNow > EveningStart and timeNow < EveningTime then
if (
( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 5) and os.date("%H:%M", os.time()-18*60) == fibaro:getValue(1, "sunsetHour")) )
or
( ((currentDate.wday == 3 or currentDate.wday == 6) and os.date("%H:%M", os.time()-21*60) == fibaro:getValue(1, "sunsetHour")) )
or
( ((currentDate.wday == 4 or currentDate.wday == 7) and os.date("%H:%M", os.time()-25*60) == fibaro:getValue(1, "sunsetHour")) )
or
( tonumber(fibaro:getValue(LichtsensorBuiten, "value")) < 25 )
then
fibaro:call(GordijnVOpritijde, "Close");
fibaro:debug("GordijnVOpritijde Close ")
fibaro:call(KeukenkastjePlint, "turnOn");
fibaro:debug("KeukenkastjePlint Light On ")
setTimeout(function()
fibaro:call(GordijnVoorzijde, "Close");
end, 8000)
fibaro:debug("GordijnVoorzijde Close after 8 seconds")
fibaro:call(SpotKastLinks, "turnOn");
end, 15000)
fibaro:debug("SpotKastLinks Light On after 15 seconds ")
fibaro:call(GordijnFietsenzijde, "Close");
end, 20000)
fibaro:debug(" GordijnFietsenzijde Close after 20 seconds")
fibaro:call(GordijnAchter, "Close");
end, 28000)
fibaro:debug("GordijnAchter Closed after 28 seconds ")
fibaro:call(GordijnZkantachter, "Close");
end, 34000)
fibaro:debug("GordijnZkantachter Close after 34 seconds ")
fibaro:call(SpotBeeld, "turnOn");
end, 300000)
fibaro:debug("SpotBeeld Light On after 30 seconds")
fibaro:call(Vlagverlichting, "turnOn");
end, 2700000)
fibaro:debug("Vlagverlichting Light On after 27 seconds ")
elseif timeNow > EveningTime and timeNow < StopHour
and ( tonumber(fibaro:getValue(172, "value")) > 7 )
then fibaro:call(GordijnVOpritijde, "Close");
end, 8000)
end, 15000)
fibaro:call(GordijnFietsenzijde, "close");
end, 20000)
end, 28000)
end, 34000)
end, 300000)
end, 2700000)
setTimeout(tempFunc, 60*1000)
fibaro:debug()
