RING DOORBELL by RING.COM
before:
create two global vars, please
"RingToken" - used by the script internally
"Doorbell" - for user actions.
0 - nothing
1 - motion detected
2 - ding-dong
happy using!
Edited by 10der
Well Done and Many Thanks
On 2/6/2019 at 8:15 PM, 10der said:
function authenticate(accessToken, nextFunction)
 There are several of us who have been searching for a solution. May I ask where you were able to gain the information that populates this section or is it the same for every user?
It seemed to work briefly but now I get
[DEBUG] 09:44:40: Connecting...
[DEBUG] 09:44:40: CONNECT STATUS: 401
[DEBUG] 09:44:40: ERR"
Any ideas?
Cheers
    1st - its common solution
    2nd as I can understand (form python forum where I found python code for ring doorbel)
    it's wrong. we should use 10 or 15-sec delay.
    btw my code doesn't have this lines. lol
    Thanks for the fast feedback.
    What I attached was the debug results I was getting when I ran the scene which I thought may be coming from the data input in these sections which seem tailed to an individual
    3 minutes ago, PepsiMac said:
    postData["device[os]"] = "android"
    no
    it's a common header for ring api calling
    ring api doesn't check it at all.
    Actually, never mind.
    Edited by 10der
    OK Thanks. I will take a closer look and see if I can work out what is causing the scene to fail for me.
    please change timeout!
    as I know (now) ring ban (401) accessing if accessing less than 10-15 secs
    I have updated 1st post with source
    Edited by 10der
    There is also a bug in line 68 or 69.
    function parameter should be "err" instead of "error" or the variable name should be "error" instead of "err.
    fixed
    v2 in header
    Hi @10der, please be advised that I downloaded the v2 file but got "Operation could not be performed successfully and was interrupted. Error text: Malformed vfib file".
    The HC2 in question is running the 4.530 os.
    WUT?
    scene!!!
    Sorry, will switch on brain....
    OK, cut and paster as a scene with password etc updated.
    [DEBUG] 17:52:08: FIBARO ring doorbell checker started...
    [DEBUG] 17:52:08: 2019-02-18 17:52:08.620508 [ fatal] I/O error: End of file
    Could it be because I use the original Ring Doorbell?
    im getting same error and i also have the origional ring doorbell from 2016
    it's Fibaro @T.Konopka error since 2017y.
    support answered me officially what SSL supported partially.
    just create a new scene and run it
    if you wonder
    my doorbell
    Edited by 10der
    same problem when i created a new scene.
    i do remember it working a while ago when i tested it last time
    hey guys
    can you set
    local debug = true
    thank you!
    /monthly_2019_02/image.png.288e7ccf3520aa8e82dc6cfcc8f87078.png" alt="image.png.288e7ccf3520aa8e82dc6cfcc8f87078.png" />
    aaha!!
    uncomment 1st line
    fibaro:setGlobal("RingToken", "")
    please!
    @morpheus75
    Mine working now, think that solved the problem, uncommenting that which was on line 193 for me.
