martinreulink 1
recently i installed a new FUSB with 1 temperature sensor (DS18B20).
The problem i have, is that it will fluctuate extremly.
Attached you can see 2 sensors. The red line is a Fibaro smoke sensor, with built-in temperature sensor.
Blue is the FUSB.
Both have the same settings for reading and communicating to HC2.
Does anyone know this problem? Or have a tip to fix this?
Thanks!
