Kangaxx 0
I installed a Dimmer 2 with Bypass but have the following problem:
The two momentary switches are not working, switching from the hub works fine.
The wiring can seen below, its a combination from wiring-diagram1 & 5 at the full manual.
3-wire connection is not possible cause I have only 4 conductors between both switches and supply and lamp are at the same box and there is no space for the dimmer.
For testing purposes I did a 3-wire-connection but with the same result. I dont want to use the yellow/green (also it's not allowed) so there is just the 2-wire connection left.
Is this just a configuration problem or is there something fundamental wrong?
9 answers to this question
