write yr weather temperature to event panel
Guest Theo
I have attached a temperature sensor to my heating system. The needed temperature obviously is dependent on both the set room temperature and the outside temperature. Is itt possible to write the yr weather temperature to the event panel once per hour or so. Then I can plot them both. I would appreciate a short example of lua.
Thanks in advance.
