Beeker 0
Hi All,
Apologies if this subject has already been raised....looking for an experts that might know the answer or have the solution.
I have added a VD from the Fibaro Market place for a Panasonic TV using my HC2 on v4.530 to control the Panasonic TH-P60TST60A via ethernet which works and has no issue apart from when I try bringing the TV out of standby which does not work. I assume the ethernet port on the TV powers down when you place the TV in standby.
I want to avoid using IR and I have a Telstra TV unit which when I wake it up its brings the TV out of standby I assume using CEC on the HDMI.........is there any way of integrating either via a string or LUA to talk to the HDMI port on the TV from my HC2 using CEC?
Cheers
Beeker
