HC2 FW4530 2 issues
hello @all,
i've got to issues with my HC2 (running on 4530).
I've ~ 63 physical devices (some more will follow) connected as well lots of scenes and some virtual devices
However, when i added the last new devices i got following output on my HC2:
[18:24:42] Home Center ist im Lernmodus.
[18:24:46] Modul hinzugefügt
[18:25:03] Hinzufügen des Modul abgeschlossen.
[18:25:26] ID 480: Set association for group 1
[18:25:27] ID 480: Received association report from group 1
[18:25:27] ID 480: Received association report from group 2
[18:25:28] ID 480: Received association report from group 2
[18:25:28] ID 480: Set association for group 1
[18:25:29] ID 480: Received association report from group 1
[18:25:29] ID 480: Received association report from group 2
[18:25:34] ID 0: Overload detected. Reduce the load connected to the output.
[18:25:40] ID 480: Device configuration finished
After this the device is included and working. This happened to 3 devices, so the should be no coincidence.
Additionally i've a setup, where my HC2 is connected to a switch.
HC2 gets same DHCP IP from both routers, depending which device is on.
On this switch i've my MAIN & BACKUP Router connected.
So in case my Main router fails (virtual ip interface, which i check with a virtual device and then run a scene to turn off & on 2 wallplugs) i start a scene with a countdown to turn on my backup router and then turn off my main router.
This setup is actually working and i will have ~ 3-5 min no internet connection, depending that the xDSL is still available. Next step could be a LTE dongle in backup router, so i could have LTE Backup too.
However, i saw several times in my tests, that the HC2 just "disappears". Also the Fibaro Finder can't find it anymore. So i need to reboot it hard everytime.
Do you have any suggestions or possible solutions?
BR
snoopy78
