Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
Fabir
4 Heat Controller FGT-001 in one heating zone, the Reference Thermostat in the plugin isn't selectable
Hello
I have a room with 4 heating radiators and would like to use 4 Fibaro FGT-001 Heating Controllers in 1 Heating zone.
The additional thermostat FGBRS-001 for the Fibaro Heating Controllers, can only be connected with up to 3 Heat Controllers.
Therefore I would like to use another temperature Sensor in this room, as the Reference Temperature Sensor.
My Home Center Light is on Release 4.531 Beta
For testing, I have already 1 Fibaro Heat Controller FGT-001, it is on the latest Firmware 4.5
In the Fibaro  Thermostat &Heating Plugin, that is steering the Heating Zones, I can only choose the Thermostat from the Fibaro Heat Controller, no other Temperature Sensor in the Room, for Instance a Fibaro Door/Windows Sensor.
Is this a bug or a feature?
Thanks for the help in advance
Fabir
Edited by Fabir
Share this post
Link to post
The main temperature sensor in a room is set from the Room view in the top bar if that is what you are after. Any temperature sensor can be selected there.
Share this post
Link to post
  • Momos @
    Hi, thank you for your message.
    I'm talking about the Thermostat & Heating Plugin that is designed to be used together with heating zones.
    Look below, the second picture that's where I can't select another Reference Thermostat than the Thermostat on the Heat Controller
    Best regards,
    Fabir
    Share this post
    Link to post
    Ahh you got me... in all the years with HC2 i had no idea that plugin existed.... i just use the heating panel.
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
