Heating panel or Fibaro Heat doesnt work
hello
i created a schedule at 19°C but the valve doesn´t close and the temp rises above 20°C. Is this problem of HC2 heating Panel or the heating controller? i created  a scene that the heat controller has to set 10°C when temp in room is above 19,2°C and set 19° when its below 18,5°C. That works very well so i could test the room sensor.
Hi, it's not quite clear to me, what you mean?
Do you use:
Fibaro Heat Controllers or other Brand Heat Controller?
The Fibaro Temperature & Heating Plugin?
Do you use Heating zones?
Can you show the Scene?
Best Regards, Fabir
    i use fibaro heat Controller
    there are 2 in my living room
    this is a heating zone
    i use the normal heating plugin and set it to 19°C and the heat Controller doesn´t Close so it rises up to 20°C and more
    tomorrow i can show the scene
    if temp is equal or higher 19,2 °C than set heat Controller to 10°C
    and
    if temp is equal or lower 18,5°C than set heat Controller to 30°C
    but i used this only to check heat Controllers and temp sensor
