Scenes triggered by status change of device
I want to make a scene that works like this:
When I trigger my Verisure alarm, the Verisure smart plug sets to off. I have a Fibaro wall plug that then gets W=0.
If Fibaro plug W=0 then between 90 min after sunset and 22:45 the Sonos will play radio (this I know how to do).
but if I come home and disalarm the Verisure, the Fibaro gets W>0, and then when trying to play my Sonos, it will almost imediately stop due to that the Fibaro W is not equal to 0.
So what I like to achieve is:
When Verisure is alarmed and clock is between 90 min after sunset and 22:45, then play Sonos.
When Verisure is not alarmed, be able to play Sonos.
If Verisure is alarmed and the Sonos i playing, and I come home and disalarm the Verisure, stop playing.
Is there a way to trigger the "Stop playing Sonos" when a device is changing its state? Meaning, if Fibaro goes from W=0 to something else then trigger the scene?
Hi. Did you find out how to do this? I'm looking at the same thing, where I want a trigger on a Fibaro Wall plug being changed to 0W. And then perform some operations.
    No answer so far.
    Please help me to solve this issue!
    Hi, Perhaps post your LUA.
    I had the same and overlooked that a command was written wrong, with a cpital instead of low cap.
