Lua running in main loop but not in a button???
Hi
I have some code which is running fine in the main loop but when I copy the EXACT code into a button it does not run at all...
the debug screen stays blank.
Is there a difference in handling between those except one rinning in loop?
Example of the code:
7 answers to this question
Lua code runs in main loop only.
To run the code in button, you need to press the button. This is the hole idea of having buttons.
    Yes I understand of course ;D
    But it does not run when pressing the button too!!
    and yes, the "lua" is marked
    Edited by twannieguitar
    No errors also?
    I'm trying to understand you code and looks like the code runs OK, but you did some strange case
    if (nano == nil)
    then nano = Net.FHttp(ipAdress,port)
    else
    Since when you press the button nano is NIL, so nothing executed
    Please try as follow
    Edited by cag014
    i think i know... i did some testing but it has to do with
    The main loop memorizes "nano" as a global value...  a button is local!
    Yes, this is correct
    thanks for thinking with me
    That line wass still in there from original device...
