Scene activation with consumption monitoring device
Here is my problem:
I have to create a scene for my greenhouse that lets me start a heater and so far everything is simple.
I have a smart meter and I would like the heater to start only under certain conditions such as temperature type below 15 degrees, in a certain amount of time and consumption in watts less than 2900W.
No problem for the temperature and time interval but when I enter the consumption the scene "stripping".
Transforming a block scene I made this code that seems to work but actually runs only once even if there is the autostart.
What am I doing wrong?
Here is the lua code I am setting up:
%% autostart
%% properties
551 value
719 energy meter
%% weather
%% events
%% globals
local energyMeterID = 719
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
powerNow=api.get("/energy/now-1/now/single/devices/power/"..energyMeterID)
if (
 ( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "16", "00")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "08", "59"))) and (math.floor(os.time()/60)-math.floor(1550131200/60))%1 == 0 )
and
 ( tonumber(fibaro:getValue(551, "value")) <= 15  and powerNow.W <= 2900 )
then
    fibaro:call(619, "turnOn");
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
 ( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "16", "00")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "08", "59"))) )
and
or
then
    Resolved, they helped me on the French forum.
    The block scene converted to lua gave me this code for the time interval:
    Instead it was written like this:
    (tonumber(os.date("%H%M")) <= 0859 or tonumber(os.date("%H%M")) >= 1600)
