lboele 1
Hi everyone,
I am struggeling a lot of time with the following issue. My situation:
I have a Dimmer 2 and a Double relay switch.
If I turn on the Dimmer 2, I want to turn on one of the relay's of the relay switch.
I want that to do with assocations.
I managed to get it working, if I push the button, the relay switched on, that's good! But if I turn on the Dimmer by the webinterface of the HC2 the relay is not switching.
What am I doing wrong?
Thank you in advance!
