Disable physical switches in scene
Hi, is it possible to disable physical switches during an (alarm) scene?
I have door and motion sensors. When armed and breached I would like to switch on the lights and disable the physical switches so that a 'burglar' cannot switch the lights back off.
I'm using fibaro dimmer 2 and fibaro switch 2 modules.
I'm looking for a solution using Lua code.
Thanks!
4 answers to this question
    any takers???
    On 3/4/2019 at 5:29 AM, harmdelaat said:
    any takers???
    did you work this one out? I am looking to do the same
    Hei, i found this scene on the forum, all credits to Jan -Paul van Burgsteden. I have changed it slightly for your needs.
    Copy to new lua scene , set Run scene :Automatic and  Do not allow alarm to stop scene while alarm is running.
    Edited by MARCUSP.I.L
    format
