AlexFl 2
Hello all,
I need your help, because I am struggeling to find a solution for controlling my lights via HC2.
Did anyone controlled Livolo Zigbee Gateway using the HC2?
Livolo Zigbee Gateway link
Livolo Zigbee touch switch link
The background is following: since I do not have a neutral lead available in the wall switch socket, I cannot use Fibaro single Switches to control the lights, because it is not working without having the neutral lead available. I know that there is a possibility to use the Fibaro dimmer without neutral lead, but I wanted to use touch switches. I found out that Livolo Zigbee touch switches can be used without neutral lead and was hoping that someone of you know how can I integrate Livolo Zigbee via the livolo zigbee gateway to HC2.
If someone has a better solution, I am very happy to hear it. I did not buy yet the Livolo Zigbee touch switches but I already have the normal Livolo touch switches like in link below:
The idea to use Livolo Zigbee touch switches comes, because I can reuse the glass panels that I already have.
Hope that I made myself clear and that someone can help me further.
Thank you in advance.
Best Regards,
Alex
