Number of instances of scene has been reduced due to exceeding limit.
hi all ,
trying to understand this above message , below is a very simple scene , if on of my lights is on then the relevant variable will turn on ( see attached ) .
not sure why is it causing me this above alert. (Number of instances of scene has been reduced due to exceeding limit. )
thanks
4 answers to this question
+1  the same problem here...
I'm having the same issue with arm / disarm notifications with block scenes. I have 30+ sensors...
Have you tried increasing the maximum running instances allowed (max=10) ? As I can see you have 2 allowed on the photo.
" to "
Temat został przeniesiony z "
" do "
Increase the max instances to 4.
And add the screen shot of the message you see - it is the most crucial part of your issue and you did not include it ;)
