Sjakie 157
Hi Guys,
Subject:
1)Before arm the house >>>>check doors or windows are safe
2)If not play Sonos and stop scene
3) if all safe than arm the house
What diid I do:
1)Created scene to check sensors>>> ok
2)PlaySonos>>>>>>ok
3)stop scene here I go wrong. In my LUA is lse if ..... but Sonos also play if all sensors are safe
Who can fill in the gap or point me in the right direction
%% properties
54 value
59 value
172 value
176 value
221 value
77 value
%% weather
%% events
%% globals
function debug(color, message)
fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"));
--------------- Use function----------------------------------------------------
debug("red", "Check all door- and window sensors if they are safe then Arm (aanwezig) ");
-- Use colours like "white", "orange", "white, "green", "grey", "red", "blue".
debug("orange","scene start")
debug("yellow", "switch Sonos off does not work")
--Hal
local ElrocontactAlarm = 69
local DeurHal = 59
local DeurHuis = 54
--Hoofdslaapkamer
local DeurHoofdslaapkamer = 173
--GastenkamerBoven
local RaamSensorRechtsGastBoven = 77
local RaamSensorLinksGastBoven = 221
local DeurGastboven = 176
--Woonkamer
local Ipcam = 6
local BewegingsmelderWoonkamer = 166
local StekkerStoelSjaak = 14
local StekkerStoelArleta = 18
local TVStekker = 16
--Eetkamer
local BewegingsmelderEetkamer = 145
--Keuken
local VerlichtingLedstripKeuken = 20
local StekkerAfzuigpkap = 214
local SonosPlayer = 212
--Zoldeer
local ZolderAfzuigunitSnelheid2 = 134
local ZolderAfzuigunitSnelheid3 = 132
local VerlichtingSpotKastLinks = 203
local VerlichtingHoofdslaapkamer = 117
if (
( tonumber(fibaro:getValue(54, "value")) > 0 )
--;then debug("red","deur open");
or
( tonumber(fibaro:getValue(59, "value")) > 0 )
or
( tonumber(fibaro:getValue(172, "value")) > 0 )
or
( tonumber(fibaro:getValue(176, "value")) > 0 )
or
( tonumber(fibaro:getValue(221, "value")) > 0 )
or
( tonumber(fibaro:getValue(77, "value")) > 0 )
or
then
fibaro:call(SonosPlayer, "pressButton", "7");
fibaro:call(SonosPlayer, "setSlider", "15", "60");
setTimeout(function()
fibaro:call(SonosPlayer, "setSlider", "15", "25");
end, 3*60*1000)
fibaro:debug("Sonos op lager volume na 3 minuten")
-- setTimeout(function()
-- fibaro:call(SonosPlayer, "turnOff");
-- end, 3*60*1000)
-- fibaro:debug("Sonos uit")
elseif
--( tonumber(fibaro:getValue(59, "value")) == 0 )
( tonumber(fibaro:getValue(54, "value")) == 0 )
and
and
( tonumber(fibaro:getValue(172, "value")) == 0 )
and
( tonumber(fibaro:getValue(176, "value")) == 0 )
and
( tonumber(fibaro:getValue(221, "value")) == 0 )
and
( tonumber(fibaro:getValue(77, "value")) == 0 )
and
then
--Hal_Overloop
fibaro:call(DeurHal, "setArmed", "1");
debug("green","DeurHal Armed");
fibaro:call(ElrocontactAlarm, "setArmed", "1");
debug("green","ElrocontactAlarm Armed");
fibaro:call(DeurHuis, "setArmed", "1");
end, 45000)
debug("blue","DeurHuis Armed after 45 seconds");
--Hoofdslaapkamer
-- fibaro:call(DeurHoofdslaapkamer, "setArmed", "1");
-- debug("green","DeurHoofdslaapkamer Armed");
--GastenkamerBoven
fibaro:call(RaamSensorLinksGastBoven, "setArmed", "1");
debug("green","RaamSensorLinksGastBoven Armed");
fibaro:call(RaamSensorRechtsGastBoven, "setArmed", "1");
debug("green","RaamSensorRechtsGastBoven Armed");
fibaro:call(DeurGastboven, "setArmed", "1");
debug("green","DeurGastboven Armed");
--Woonkamer
fibaro:call(Ipcam, "turnOn");
debug("green","Ipcam Switched On");
fibaro:call(BewegingsmelderWoonkamer, "setArmed", "1");
debug("green","BewegingsmelderWoonkamer Armed");
fibaro:call(StekkerStoelSjaak, "TurnOff");
debug("green","StekkerStoelSjaak Switched Off");
fibaro:call(TVStekker, "TurnOff");
debug("green","TVStekker Switched Off");
fibaro:call(StekkerStoelArleta, "TurnOff");
debug("green","StekkerStoelArleta Switched Off");
--Eetkamer
fibaro:call(BewegingsmelderEetkamer, "setArmed", "1");
debug("green","BewegingsmelderEetkamer Armed");
--Keuken
fibaro:call(StekkerAfzuigpkap, "turnOff");
debug("green","StekkerAfzuigpkap Switched Off");
fibaro:call(VerlichtingLedstripKeuken, "turnOff");
debug("green","VerlichtingLedstripKeuken Switched Off");
--Serre
--Zolder
fibaro:call(ZolderAfzuigunitSnelheid2, "turnOff");
debug("green","ZolderAfzuigunitSnelheid2 Switched Off");
fibaro:call(ZolderAfzuigunitSnelheid3, "turnOff");
debug("green","ZolderAfzuigunitSnelheid3 Switched Off");
debug("orange","scene beeindigt")
fibaro:debug()
11 answers to this question
