Breaching alarm via code
Hi guys!
Is there a way to breach alarm via code or API? Say the alarm system is armed and computer vision attached to the surveillance sees a person. Is there a way to trigger the alarm via code?
Thanks!
Ros
6 answers to this question
Is not clear for me
if the door is armed you can’t send command to opening the door If the door doesn’t have additioanl relay and motors for opening
also if you arm motion sensor you can’t send mothion command to sensor ;)
but you can call a cat for example ;)  It it’s not via API
    So I would have to arm a binary sensor and then breach it with say... a switch tied to it.... would that work?
    Yep, sir. but curiously how you will arm a binary sensor...
    UPD: but if you have ZUNO... maybe OK
    Edited by 10der
    @Ros UBS! You can play with UBS.
    Just tested. OK.
    Were you able to breach via code or via an attached switch?
    No, UBS out cannot be controlled by code :(
