Sjakie 157
Hi guys,
I need your assistence agaim.
I have a lot of syntax errors if I busy with a scene.
1)Can someone give me a little bit more extended scene of lights on/of delayed of with fibaro:getvalue or with global value?
20 should I create a variable for movement and use that to switch on/off ligts or do I use the device itself. What is less triggering traffic in HC2?
Thanks in advanced
