What adapter is needed? (MMA M28x1.5)
Hello! Me and my friend bought several Fibaro Thermostats but we are having problems finding the correct adapter.. There seem to be a jungle out there with LOTS of adapters..
My radiator has a fitting called MMA M28x1.5 what adapter do i need to be able to fit the Fibaro Thermostat? The included adapters does not fit.
House is built in 2009 so not that old :)
4 answers to this question
    Might have found an adapter. According to Bauhause this one will fit MMA M28x1.5 to convert to M30x1.5 even though it says its TA M28x1.5 to M30.1.5 ... I will go there tomorrow and see.. :)
    I have used other Z-wave Thermostats, and in the end it was easier and cheaper to replace the fitting.
    Looks a lot like what I have used:
    same brand, works perfect!
    To report back. The adapter DID fit perfectly! No problems. Price for it was 4€ so it was cheap. But price varies a lot between different stores. I saw prices ranging from 4€ up to 9€.
    I did buy it at Hornbach. Bauhaus had it too but not in stock and it was around 9€ instead.
    Edited by mephist0
