amit_fibaro 0
Hello
i am using the Fibaro home center 2 and have encountered a couple of unexpected behaviors, hope one of you could clear things up
in any case thank you in advance
1) unable to update, currently fibaro is stuck in version 4.056 (came from factory ) in the configuration tab there is no update option
i have tried clearing the cache as was suggested in the forums but it did'nt matter
2) i've started working with fibaro roller shutter 3, when i added the device ( 3 quick clicks) instead of adding just one it added 3 devices
3) i've tried using the up and down buttons to roll up and down the shutter only the down button works the up button is not reacting however when i touch the continuous line it rools up the shutter, i tried configure the device parameters and even ran the parameter 150 with 2, after it did an auto calibration it didnt change a thing:-(
could you please help understand how to fix this
thanks
10 answers to this question
