[SOLVED]Adding co sensor problem
Hi... I use this beta version in HC2 and when i try to add co fibaro sensor i have these logs:
[01:26:48] Home Center in learning mode
[01:27:04] Device added
[01:27:04] Add node status protocol done
[01:27:05] Adding devices complete
and nothing happens even if i leave it for much time. It is the first time that i have this issue with a new device. Any help? Issue of this version?
Edited by T.Konopka
It's CO Sensor, not CO2 Sensor ;)
Hi @lasmartuser ,
Before adding CO2 sensor try first to delete it from the system even is not added. Exclusion or deletion of the device also resets it and makes it ready to be included. Also make sure that learning mode LED on front panel is not lit before starting learning (adding device). If this LED is still lit even learning mode stop counting then start learning mode and while it counts down stop it and then when that LED is off then start learning mode again to add new device.
    Removing and re-adding made the difference and device is added succesfully now. Thanks #Sankotronic
    " to "
    Temat został przeniesiony z "
    " do "
