fabandroid 0
Hi Everyone!
I just join the forum.
I need some technical support.
The project is this:
Breezeway Length of Led Strips: 1 x 49' feet on the ceiling = 49' Total
3014 led strip lights 43120 LUMENS - 294 WATTS
The power supply:
Optional dimming method: TRIAC or 0/1-10V dimmable
Meet the LED lighting
Products through CE, RoHS Certification
MODEL: 24V300W
Output DC Voltage: 24V
Rated Current: 24V 12.5A
Current range: 0-12.5A
Rated power: 300W
Ripple/noise(max): 200MV
Voltage Tolerance: ±2%
Linear Regulation: ±1%
Load regulation: ±2%
Input Voltage range: 170-250VAC OR 100-130VAC
Frequency range: 50-60Hz
Power Factor(Typ.): PF>0.6/220VAC
EfficIency(Typ.): >84%
AC Current(Typ._): 1.8A/220VAC
My question is:
Can I use the DIMMER 2 in this project?
