knuth 28
Testing my first and very simple scene raised some elementary questions which I am sure some of can answer. The scene simply is "if smoke alarm is activated/breached, then switch off relay after 10 sec". Here is the block scene:
/monthly_2019_03/image.png.e26b99dcfe050c608a1e40d0d4bf0fe4.png" alt="image.png.e26b99dcfe050c608a1e40d0d4bf0fe4.png" />Røykvarsler = smoke alarm
Komfyrvakt rele = relay switch
And here are my questions:
1. In the setup, shown below, there is a check box for "Do not allow alarm to stop scene...". There is a warning to avoid checking this box. In my case it seems logical that the scene is NOT stopped by an alarm, as the trigger itself is an alarm. Do you agree? When do you actually tick this box? For all alarm related scenes?
2. The scene is set to be "automatic". Is this sufficient, or should the box "Start when HC2 starts" be ticked as well, as I have done above? What is the difference between ticked and open in this box for an automatic scene?
3. In the main interface, the scene appears with its own icon and small panel:
I assume the on/off slider to indicate whether the automatic scene is active or disabled? What about the "play" button below? When I push it, the relay switches off. Does that mean that the play button activates the "THEN statement" (here: switch off relay) regardless of trigger status?
Feel free to give your opinion on any or all of my questions. I am just starting my scenes projects and need to learn more.
8 answers to this question
