    Lol do I need ? - was hoping connecting a fibaro device would be simple with the simple wiring - 4 wires from motor and 3 wires from 240 plug ?
    Thanks for trying
    • 3 weeks later...
    Hi @Jayjay280 ,
    Here is solution how to integrate your Paramount MK1 to Fibaro HC:
    Switch 1 is important one and responsible for opening/closing garage door and it is of this type:
    It must have separated IN from L because for open/close command it is used +12VDC that is available on MANUAL terminal block.
    Switch 2 is OPTIONAL so it is not really needed except if you want to be able to stop opening/closing of garage door from your home automation.
    It is of this type:
      It also must have separated IN from L for same reason as switch 1.
    Above information is given based on this document:
    so I can't be held responsible for any possible damage by using above information.
