Making a VD sending http commands
Hi!
I'm trying to make a Virtual Device to control my Denon amplifier.
This string works as a http command in the browser window:
Quote
http://IPADRESSDENON/MainZone/index.put.asp?cmd0=PutVolumeMute%2Fon
This is the code I'm trying to use in the VD that doesn't work:
Quote
POST ./MainZone/index.put.asp?cmd0=PutVolumeMute%2Fon HTTP/1.1
Host: IPADRESSDENON
Settings virtual device:
Host: IPADRESSDENON
Port: 80 (know that this is working)
I've tried countless variables to get this working, and nothing happens. Any ideas?
Would appreciate any help!
Hi @larskheg,
maybe the solution for your problem is
    2 minutes ago, Bodyart said:
    Hi @larskheg,
    Thanks so much for helping!
    Unfortunately that VD is programmed in LUA, and LUA doesn't work for HCL, so then I need to find the way through HTTP programming :(
    I created a VD that works for Marantz
    It should work even for Denon
    please check
