Hi All
I have setup my aircon to be controlled via a virtual device over IP and it is working well, I am now creating scenes to do certain things. One of the things i want to do is set a certain temperature with certain scenes in the right conditions. This is the code for the virtual device to change the temp down, this works well
local selfId = fibaro:getSelfId()
local selfIp = fibaro:get(selfId, "IPAddress")
local selfPort = fibaro:get(selfId, "TCPPort")
local TempDec = tonumber(fibaro:getValue(237, "ui.Temp.value")) - 1
local aircon= Net.FHttp(selfIp,selfPort)
response,status,errorCode = aircon:GET('/setAircon?json={"ac1":{"info":{"order":0,"setTemp":'.. TempDec.. '.0},"zones":{}}}')
If I type IPAddress:Port//setAircon?json={"ac1":{"info":{"order":0,"setTemp":23.0},"zones":{}}} into a web browser it will set the temp to 23, the question is what code do i use in a LUA scene to send this to the aircon
Any help appreciated
I found this here on the forum and use it for my heating
    --aanroepen http request:
local http = net.HTTPClient()
function call(url)
  http:request(url, {
      options = { method = 'GET' },
      success =function() fibaro:debug(url.." ,done.") end,
      error = function(errorcode) fibaro:debug("error=" .. errorcode) end
call("http://192.168.1.101/data.json?heater=0&setpoint=169&thermostat=0") -- fill in your own IP
succes
    Thank you for your response that worked for me
