Weider 1
Hi!
I would normally use a switch here but have no neutral wire, so I had to use a dimmer in 2-wire configuration.
The lights are not dimmable as there is a 12v 65w meanwell power supply powering a led strip and 4 other lights.
So I would just be powering the 12v transformer.
The problem is that right after I turn on the dimmer it will turn off the light right away. I also suspect the dimmer restarts (Not sure though).
I've tried setting parameter 32 to Value 1 (Dimming not possible) but that didn't help.
Any ideas?
EDIT: Btw, I then did use a switch by positioning the switch to the LED power supply and getting the neutral wire there, the problem there was finding a constant live wire, which luckily was not far away to get
I would still however like to know what the problem was, so I can avoid it in the future.
Edited by Weider1 answer to this question
