Hi
I am trying to debug the output of my triggers for a scene, the scene is as follows
if (
 ( tonumber(fibaro:getValue(230, "value")) > 28 ) --Dinning Temp
and
 ( tonumber(fibaro:getValue(167, "value")) > 28 ) --Living Temp
and
 ( tonumber(fibaro:getValue(190, "value")) > 31 ) --Bedroom Temp
and
  tonumber(fibaro:getGlobalValue("OccupyCount")) == tonumber("0") --OcupyCount = 0
and
 ( tonumber (fibaro:getValue(163, "ui.solar.value")) > 3000 ) --Solar >3000kw
and
 ( fibaro:getGlobalValue("TimeOfDay") == "Afternoon"  )  -- Afternoon Time
then
how would i send the current value of each one to the debug window?
9 answers to this question
Edited by 10der
A little more elaborate
More general
@jgab cool!
    Thanks for this i have added it on but only see the following
    [DEBUG] 20:44:46: fibaro:getSourceTrigger()={"type":"other"}
    [DEBUG] 20:44:46: fibaro:getValue(230,"value")="26.5"
    Do i need to do something to get all the other values?  Also how would i name them something more standard such as bedroom 26.5
    So, the first first test is not bigger than 26.5 so it won't do the other tests...
    great thanks for you help and the explanation very much appreciated
    Woow, Awesome thank you very much!
    Sir, what do you recommend to use as default in a scene?Do you have some more "smart things to add?"
    If you  have your deviceIDs in a table (type HomeTable) you can do this if you add a mapFibaroIDs function and make some changes to traceFibaro()
    to get log printouts with the name of the id
    This is brilliant... I at the moment have not got all my device IDs into a table... do you mind sharing how I can do this and keep it updated regularly??
