Scene turn on light based on motion, lux and variable
I'm practicing with LUA but this scene has a fault but I don't know what. The debug shows no error.
What I want is; when motion is detected and lux level is lower then xxx and one of the two variables has the value thuis then turn on light.
Thank you in advance
Kevin
Edited by kevin
6 answers to this question
call call calll call
but what you think about fibaro:getValue
try it ;)
    try it ;)
    Thanks you for your reply. I actually don't know what to change now:oops:. I have tried some things but that doesn't solve it. Do I only need to change a line or do I have to add more lines with code? If I need more lines with code then I really have to find out what to do
    If you will change lines with “if” call on “getvalue” you can solve your issue ;)
    please try. Do not ask help please try. Just try ;)
    all ok trust me ;)
    Ahh
    also replace breached on value  and compare eq with 1
    Edited by 10der
    I'm trying and trying all day long, but sadly I don't understand LUA good enough to see what I need to change:-(.
    I now have:
    I think the main issue is the Lux value, how can code that if the lux value is lower then xx
    Edited by kevin
    try this change the three ID's to the number of your devices
    if (
     ( tonumber(fibaro:getValue(ID, "value")) > 0 ) -- Motion
    and
     ( tonumber(fibaro:getValue(ID, "value")) < 500 ) -- Lux
    and
    ( fibaro:getGlobalValue("Kevin_locatie") == "Thuis" or fibaro:getGlobalValue("Suzanne_locatie") == "Thuis")
    then
        fibaro:call(ID, "turnOn");
    Edited by Dman568
    if (
     ( tonumber(fibaro:getValue(ID, "value")) > 0 ) -- Lights
    and
    and
    then
    Many many many thanks!!:-D I first tried the code you provided with the ID's and that was working. Now I changed it back to the HomeTable names and it's working also.
    Now I can go to sleep without thinking what was wrong:-P
