MCO Home Thermostats reading only 'auto' settings instead of 'manual'
Hi everyonae, I got an HC2 gateway and six MCO Home – Water Heating Thermostat with humidity sensor Version 2, my problem is that fibaro gateway reads out only auto mode.
Can someone help me with this problem? I have to change every time temperature because of that.
Thank you.
hi @S.mihai
Which model MCO thermostad are you using ?
    hi @malitan
    i used MCOEMH7H-WH...
    thank you
