Carsten6000 0
using Radiator Thermostat starter pack.
Several problems occured.
Using right now Samsung Smartthings - but just ordered HC Lite.
1.st problem - not able to connect to external thermometer
2nd problem - not able to factory reset
As far as I noticed I should be able to connect up to 3 radiator thermostats to 1 thermometer.
When trying to get thermostat to show blue color and confirming with 1 click - it doesn´t start to connect when applying 1 click on the thermometer it doesn´t seem to connect.
Tried to remove from z-wave network. And then do the factory reset - but again it doesn´t work.
What to do?
Anyone knows what happens if you install the radiator thermostat vertical?
Carsten
