ADalla 0
Hi Everyone. In first place, sorry about my english. It's a newbie question. I'm using HCL and LUA is not a solution for this question
i created a Virtual Device to send IR codes to a Global Cache iTach and it works fine but it's not good enough due I need run a scene and then find de specifc device to coninue the task. For exemple, if I want watch Apple TV I need press the scene button "Watch Apple TV" and it will turn On the TV, turn On de receiver, set the correct HDMI input... After scene ends, I need find the Virtual Device ( Apple TV @ Home Theater) that conains de Apple TV cursors, receiver volume, etc. The question is: Can I create a button in this Virtual Device to run the scene? Thus i should only clic the virtual device and then press a "Start" button to run the scene "Watch Apple TV" Is it possible without LUA? The command fibaro:startScene(sceneID) didn't work.
Thanks!
Alessandro
