Inblue 1
I'm really kind of desperate figuring out how to solve this problem:
I created a block scene so that the motion sensor in the corridor sets dimmer @20% on motion but only when it's dark (lux sensor of the motion sensor) and then it switches off after 60s.
The problem is, when I need 100% light, I simply push the wall switch and it goes to 100%, but as soon as the motion sensor sees motion, it sets the value again at 20%.
I really can't figure out how to give the wall switch a "higher priority" in order to override the motion scene.
Is there some easy way to do this that maybe I'm not considering?
Thank you for your help!!!
