garage door motor only pulse
Emilio
Hi All,
Ik have bought the hc lite and the shutter 3.
now i have the following question. My garage door motor only needs a pulse... just short connection of the 2 motor cables and the door wil open close or stop.
So I have connected the following
N and L to the normal power to power up the device.
Q1 and Q2 to the garage door motor for the pulse connection
S1 to the pulse button
S2 directly back to the motor.
ofcourde the normal pulse (push button) still working.
But unable to get the Q1 and Q2 to send a pulse connection to the motor to open or close or stop the door.
Set the config to gate without position... and also tried a lot of other settings, is this possible without power (N) or (L) on switch S1 or S2?
Thanx for your help
Emiel
Try to relay switch FGS212
To the pulse IN and Q and make The following parameter needs to be set:
  • 4 - 10 - turns channel 1 off after 1sec (setting is in 0.1s increments) or 2 sec your decision
  • Thanx its solved just recieved the relay and it's working many thanx
