Dimmer 2 as a switch
Hi.
I have two lights that are non-dimmable (sp?) and two dimmer 2 modules laying around. Is it possible to configure the dimmer 2 as a switch or should I buy a switch instead?
4 answers to this question
4 hours ago, Tiwas said:
Hi.
Yes it is. As a matter of fact, the dimmer2 will try to dim the source the first time it is powered on. If the source is not dimable, the dimmer2 will work as a normal switch.
    Thanks. After reading the manual I was almost sure about that, but figured I'd ask just in case I misunderstood. I found an "old" FGS I can use on the light source I know for sure is not dimable, and I'll use the dimmer 2 on the one I hope maybe will support at least a couple of steps :)
    @Tiwas During the calibration process the load may be recognised as dimmable - even if it is not designed or preferred to be. Parameter 32 enables you to set your preference in case calibration did not detect the load as non-dimmable.
    Parameter 32
    On/Off mode
    This mode is necessary while connecting non-dimmable light sources. Enabling parameter 32 automatically ignores brightening/dimming time settings. Forced auto-calibration will set this parameter’s value to 2.
    0 - on/off mode disabled (dimming is possible)
    1 - on/off mode enabled (dimming is not possible)
    2 - mode selected automatically
    Parameter 32
    On/Off mode
    Thanks!
