Hi All,
Up  unitll a few months ago I could find a list of Lua Fuctions for fibaro explained op de FibaroUK site
can someone give me a hint?
and apparently the Fibaro Academy is only for installers. Well, ... I install and program a lot, but only in my own office environment. I guess that does not qualify to become an installer.
thanks
Edited by robd
Not so easy to find these days but check knowledge section of forum ...
that gives two resources -  lua functions specific to HC2 and rest API definition.   Note.  You get the latter more usefully from <your hc2 Ip/docs>
    thnx
    probably a typical newbe question.
    one of the functions is fibaro:getSourceTrigger()
    so far so good.
    I have the Aeotec Wallmote as example.
    if I list all the triggers, properties and actions I expect to have seen all.
    so I program this:
    which returns an array with information.
    the docs state that if the returned type = "property" I also get the additional fields DeviceID and the propertyName in the array
    and now surprisingly I find 2 undocumented Properties:
    in the 'event' element it looks like I find a property "keyId"
    and in the 'data' element I seem to find a property "keyAttribute"
    well, I can't map the code to the docs...
    thanks for any help
