Couple of FGS-211 questions
Hi.
Just hooked up an old FGS-211 to replace a failed device. However, there are a couple of things I'm unable to find in the manual. These are related to the switch type. I've set it up with a normally open momentary switch (one that pops back after you push it). As far as I can see, param 14 should be set to 0 for this, but it still works like a normal toggle switch. I haven't found a parameter for NC or NO. Could someone please help me out.
Thakns!
