How to find Z-wave network_key
How to find Z-wave network_key that fibaro is using?
I want to run Home Assistant in parallel wilh my fibaro the need the  Z-wave network_key
Anyone know how to find this ?
FYI, I use the
to integrate the HC2 Gateway. Made a new 'dedicated'  HA-user in HC2, to limit access control for HA needed devices only.
I know this is not an answer to your question, though....;-)
@dkcsn
HC2 stand-alone zwave server with build inside zwave chip
you can’t use HC2 with others home automation systems natively and others systems can’t use zwave chip inside HC2 for adding   Zwave devices. You can use other home automation systems only via http bridge via HC2 API.
if you want to use other home automation system and add native zwave devices you should to buy any Zwave USB sticks
Edited by 10der
