Can't get Alarm Panel Scene to send push notification
So I have used push notifications successfully on individual devices. I have now set up the Fibaro Alarm Panel and can arm and disarm all of the sensors successfully and also using the Iphone Home Center App. I have now created three scenes using the Magic Scene creator - Alarm Set, Alarm Unset and Alarm Activated.  ach is designed to send a push notification to my phone, but I cannot get them to do that.
Taking the Set Alarm one as an example I have configured the scene as shown.  I have set up the notifications OK.  But when I set all the sensors succesfully it fails to send the push notification.  Any help appreciated.  Thanks
Very basic scene , should work.
Check Configuration - Access Control - and check that your phone is listed on Installer access.
If not look further down on Mobile devices (devices with app installed).
Otherwise check your phone settings for notifications.
Finally check Panels -Notifications Panel and see if your title and content are active.
By the way you can push interactive notifications if you wish to run/ cancel   alarms.
Bit a newbie myself so always looking for tips.
Marcus
