Smart Implant - scene activation
Guest dobsovicj
please, can you help me with scene activation of Smart Implant?
I can use it on other devices (NodOn, etc.), but I dont know what must be a trigger in head of LUA script...
Parameters 40 and 41 are checked, of course, and monostabile inputs are set.
Did anybody tried it already?
Thank you.
4 answers to this question
Guest dobsovicj
    please, did you test the Smart implant with scene activation?
    Thank you for help...
    Guest cuprum
    Does You need the separate scene or... may-be it's sufficient to use just "Reaction" in remotes if-then panel? Actually You can also call the scene from there (NEW reaction for button/sequence You need).
    But if You really need an "pure scene", then may be
    And of course 520 is my personal device number - You must use Your own...
    Producing something like
    Quote
    [DEBUG] 10:03:18: Called event {"type":"event","event":{"type":"CentralSceneEvent","data":{"icon":{},"keyId":2,"keyAttribute":"Pressed2","deviceId":520}}}
    Guest dobsovicj
    @cuprum Thank you for your answer, I will test it... I didnt know CentralSceneEvent commant, only SceneActivation.
    Guest cuprum
    Yeah, first of all i also attempted with SceneActivation (it's tested - working with Aeon's key-fob ). But then (yes, got implants at the right moment) checked the GUI-s pre-built code insertion, and found ths CentralScene events ;)
