Sjakie 157
Hi Guys,
I am doing something wrong but can not detect what!
Can somebody please correct my scene?
The GV is created
Error message
Thanks in advance
/monthly_2019_03/image.png.497709486e748ace74c7a3dba712d0c9.png" alt="image.png.497709486e748ace74c7a3dba712d0c9.png" />--[[
%% autostart
%% properties
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
local debug = true;
-- check script instance count in memory
if (tonumber(fibaro:countScenes()) > 1) then
if debug then fibaro:debug("Script already running."); end
fibaro:abort();
if debug then fibaro:debug("HC2 start script at " .. os.date()); end
while true do
local ochtendgloren = (os.time()+50*60) == fibaro:getValue(1, "sunriseHour")
local avondrood = (os.time()-50*60) == fibaro:getValue(1, "sunsetHour")
local currentTime = os.date("%H:%M");
local TimeOfDay = fibaro:getGlobal("TijdStip");
if ( ochtendgloren <= currentTime and currentTime < avondrood and TijdStip ~= "Ochtendgloren" )
then
fibaro:setGlobal("TijdStip", "Ochtendgloren");
if debug then fibaro:debug("Ochtendgloren"); end
elseif ( avondrood <= currentTime and currentTime < ochtendgloren and TijdStip ~= "Avondrood" )
then
fibaro:setGlobal("TijdStip", "Avondrood");
if debug then fibaro:debug("Avondrood"); end
fibaro:sleep(60*1000);
else
fibaro:debug("Script can only be run via autostart");
