Webhook requests not working in 4.540
Hi
After upgrading to 4.540 my webhooks commands from the HC2 are not received by Webhooks in IFTTT..
Can someone test this please?
edit:  it seems to only not work with triggers for the Nest thermostat
Edited by twannieguitar
6 answers to this question
12 hours ago, twannieguitar said:
Hi
Cannot help you there. But what do you think about IFTTT and security? You probably know, that communication to and from IFTTT is stored unencrypted on their servers? Do you have any experiences with opening up your communications to third parties and Fibaro?
Edited by Thomasn
    Yes... but I am limiting to the Nest thermostat only... I noticed the webhook commands are not encrypted indeed...
    I thinkd encryption could be made possible by Fibaro, if they wanted
    I need a wifi thermostat which works perfect with the HC2 like the Nest did a bit at some time...  so a thermostat which I can move arond and not fixed to the wall...
    Any suggestions?
    nest and ifttt service is down at the moment. its been down for 2 days
    aha... thanks for letting me know... no need to look further then :D
    8 hours ago, twannieguitar said:
    Nest seems back online
    it is my Nest worked this morning!
